Exit Print View
You can quit vtsk only if the system status is idle.
./vts_cmd quit
The VTS kernel (vtsk) is terminated. A confirmation message with the word DONE in it verifies that the operation was successful.
CLI Overview
View the Host Configuration
Configuring the Test Session (CLI)
Begin the Test Session (CLI)
Monitor the Test Session (CLI)
Stop the Test Session (CLI)
Review the Log Files (CLI)
Deleting the Log Files
Reset the Test Session (CLI)
Saving a Test Configuration for Repeated use (CLI)
Reprobe the Devices (CLI)
Use the Auto Mode Sequencer (CLI)
