Oracle VTS 8.1.0 Software User's Guide
Exit Print View
Updated: June 2016
25-Pin Port A-to-Port B Plug
These pin connections are for connecting the first plug to the second plug for most systems.
First Plug
Second Plug
Pin 16
Pin 2
Pin 3
Pin 14
Pin 13
Pin 4
Pin 5
Pin 19
Pins 6 and 8
Pin 11
Pin 12
Pin 20
Pin 18
Pin 24
Pins 15 and 17
Pin 25
image:25-Pin RS-232 Port A- to-Port B Plug Wiring Diagram
Related Information
