Oracle VTS 8.1.0 Software User's Guide
Exit Print View
Updated: June 2016
Host Bus Adapter Test Setup
Some HBA tests, such as those for Emulex and Qlogic HBA, provide external connector testing capability. For these tests, you must connect an external connector before enabling the external subtests.
External loopback specifications for Oracle's Sun Storage 10GbE FCoE PCIe Converged Network Adapter uses QLogic technology, and multi-mode fiber-optic cable, intended for short-wave lasers. For additional details, refer to Sun Storage 10GbE FCoE PCIe Converged Network Adapter Installation Guide.
Note - HBA tests can be run in component stress mode. If you have disks connected to an HBA controller that requires testing, you must suspend all the I/O operations on those disks.
See Understanding the Tests for information on connectors.
Related Information
