Oracle VTS 8.1.0 Software User's Guide
Exit Print View
Updated: June 2016
Starting the Software (CD/DVD)
You can also start the software using the bootable CD/DVD that is delivered as a part of your system or a bootable CD/DVD that you have created. You can download the ISO image from the Oracle download center. To burn the ISO image to the CD/DVD, you can use any CD/DVD burning device and software.
Note - You can only use the CD feature on Oracle x86 platforms.
Related Information
