Oracle VTS 8.1.0 Software User's Guide
Exit Print View
Updated: June 2016
25-Pin Port A-to-A Port B-to-B Plug
If your system has a single I/O port to connect it to peripherals, use these connections to make a male 25-pin plug for that I/O port.
First Plug
Second Plug
Pin 3
Pin 2
Pin 5
Pin 4
Pins 6 and 8
Pin 20
Pin 12
Pin 11
Pin 13
Pin 19
Pin 16
Pin 14
Pins 15 and 17
Pin 24
Pin 25
Pin 18
image:25-Pin RS-232 Port A-to-A Port B-to-B Plug Wiring Diagram
The following are the materials used for this plug:
  • PCR-E96FA (1)
  • PCS-E96LKPA (1)
  • 3751 metal plug (1) (9563K42)
  • AWG28 Madison cable (8 in. long) UL/CSA Approved
Related Information
