Oracle VTS 8.1.0 Software User's Guide
Exit Print View
Updated: June 2016
Memory Test Configuration File Parameters
Parameter
Description
Memory_Vmemtest_ReservePercent PercentageValue
Paramter to override the test's argument, reserve.
The PercentageValue is an integer value between 0 to 100.
For example:
Memory_Vmemtest_ReservePercent 33
Memory_Vmemtest_ReserveFactor FloatingPointValue
The PercentageValue can be a value between -1.0 to 128.
For example:
Memory_Vmemtest_ReservePercent 3.3
Related Information
