Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 4.0.x
Exit Print View
Updated: September 2018
Protecting Against Hardware Faults: Oracle ILOM Fault Manager
The Fault Manager in Oracle ILOM is intended to help with problems that might occur on an Oracle ILOM managed device. For instance, the Fault Manager detects and interprets errors and determines whether a fault or defect is present on a managed system. When a determination is made, the Fault Manager issues a list of hardware components that might be the cause of the problem.
For additional information about how Oracle ILOM helps to enhance uptime when hardware faults are detected on a device, see:
