Management
Connection Tasks and Applicable CLI Targets
Use the following table to help identify the applicable CLI namespace targets for Oracle ILOM
management connection tasks.
The following table does not provide the full CLI path to the
/SP target on all managed devices. For instance, to access
the /SP target from either a multi-domain SPARC server, a blade
system CMM, or a Netra FMM, append the applicable CLI properties to the beginning of
the /SP target:
SPARC multi-domain server, where applicable, append:
/Servers/PDomains/PDomain_n
Blade system CMM, where applicable, append:
/Servers/Blades/Blade_n
Netra frame system FMM, where applicable, append:
/Servers/ComputeNodes/ComputeNode_n
Note -
Not all CLI management connection targets are available on all managed
devices. Use the help command to view the namespace
targets supported on a managed device. For example, help
/SP/network, | help /CMM/network |
help /FMM/network
For additional information about setting up a management connection to Oracle
ILOM, see the topics listed in the Related Information section that appears after
the table.
View or modify the network service state property on the
server SP, CMM, or FMM.
/SP|CMM|FMM/network
View or modify the IPv4 network properties on the server SP,
CMM, or FMM.
/SP|CMM|FMM/network
ipdiscovery
ipaddress
ipnetmask
ipgateway
dhcp_clientid
View or modify the IPv6 network properties on the server SP,
CMM, or FMM.
/SP|CMM|FMM/network/ipv6
state
autoconfig=
autoconfig
static_ipaddress
Test IPv4 and IPv6 network connectivity.
/SP|CMM|FMM/network/test
View or modify the SP network management port
property.
/SP/network
Note -
Not all server SPs support the
Netn
property for enabling sideband management.
View or modify the local interconnect access properties
between the Oracle ILOM SP and host OS.
/SP/network/interconnect
host_managed
Note -
Other interconnect properties can be configured if
you choose to manually configure the connection
between the SP and host OS.
Use the help command to learn
about the other interconnect properities.
View or modify the Domain Name Service (DNS) resolution
properties on the server SP, CMM, or FMM.
/SP|CMM|FMM/clients/dns
auto_dns
nameserver
/retries
searchpath
timeout
View or modify the serial management port property on the
/SP|CMM|FMM/serial
external
host
portsharing
Note -
The serial port properties vary from system to system. Use
the help command to determine which
serial port properties are supported on the managed device.
For example: help /SP/serial
