Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 4.0.x
Exit Print View
Updated: September 2018
Fault Management Shell Session Task and Applicable CLI Target
Use the following table to help identify the CLI namespace target for the Oracle ILOM Fault Management Shell. This table does not provide the full CLI path to the /SP target on all managed devices. For instance, to access the /SP target from either a multi-domain SPARC server, a blade system CMM, or a Netra FMM, append the applicable CLI properties to the beginning of the /SP target:
  • SPARC multi-domain server, where applicable, append: /Servers/PDomains/PDomain_n
  • Blade system CMM, where applicable, append: /Servers/Blades/Blade_n
  • Netra frame system FMM, where applicable, append: /Servers/ComputeNodes/ComputeNode_n
All component faults reported in Oracle ILOM are automatically cleared upon the service repair or replacement of the component. For detailed information about the Oracle ILOM Fault Management Shell or the open problems reported in Oracle ILOM, see the topics in the Related Information section that appears after the following table.
Note -  The purpose of the Oracle ILOM Fault Management Shell is to help Oracle Services personnel diagnose system problems. Customers should not run commands in the shell unless requested to do so by Oracle Services.
Fault Management Task
CLI Properties on Managed Device
User Role Required
Launch the Fault Management shell to diagnose system problems on a server SP, CMM, or FMM (as instructed by Oracle Service).
/SP|CMM|FMM/faultmgmt/shell
  • Admin (a)
Related Information
