Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 4.0.x
Exit Print View
Updated: September 2018
Firmware Update Tasks and Applicable CLI Targets
Use the following table to help identify Oracle ILOM firmware update tasks and CLI targets.
The following table does not provide the full CLI path to the /SP target on all managed devices. For instance, to access the /SP target from either a multi-domain SPARC server, a blade system CMM, or a Netra FMM, append the applicable CLI properties to the beginning of the /SP target:
  • SPARC multi-domain server, where applicable, append: /Servers/PDomains/PDomain_n
  • Blade system CMM, where applicable, append: /Servers/Blades/Blade_n
  • Netra frame system FMM, where applicable, append: /Servers/ComputeNodes/ComputeNode_n
Note -  Not all firmware CLI targets are supported on all managed devices. Use the help command to view the namespeace targets supported on a managed device . For example,
help /SP/Firmware | help /CMM/Firmware | help /FMM/Firmware
For detailed information about how to perform Oracle ILOM firmware updates, see the topics listed in the Related Information section that appears after the table.
Firmware Tasks
CLI Properties on Managed Device
User Role Required
View system BIOS properties or update system BIOS image (x86 only).
/System/BIOS
  • system_bios_version
  • boot_mode
    Note -  To change the BIOS boot mode, refer to the adminstration guide provided for the server.
  • reset_to_defaults
  • /Config load_uri
  • Read only (o
  • Admin (a) for loading new image.
View the Oracle ILOM firmware version installed.
/System/Firmware
  • system_fw_version
  • Read only (o)
Update the SP, CMM, or FMM firmware image.
/SP|CMM|FMM/Firmware
  • load_uri
  • /host/miniroot
  • /keys
  • /backupimage
Note -  Not all firmware update properties listed in this table are supported on all managed devices. To determine which properties are supported, use the help command (help /SP|CMM|FMM/firmware)
Note -  SPARC server platforms require the host operating system to be powered-off prior to performing the firmware update.
  • Admin (a)
View or update NEM firmware from the CMM.
/System/Firmware/Other_Firmware/
  • Firmware_n (choose an associated NEM)
  • load_uri
  • version
Note -  NEMs that do not support service processors will not be listed under the firmware target.
  • Admin (a)
View switch firmware version from FMM.
/System/Networking/Switches/Switch_n
  • firmwmare_version
  • Admin (a)
Update blade chassis component firmware from the legacy CLI target.
/CH/BLn/SP/NEMn
  • load_uri
Note -  The host operating system on SPARC servers must be powered off before performing a firwmare update.
  • Admin (a)
Related Information
