Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 4.0.x
Exit Print View
Updated: September 2018
Executing Commands to Change Target Properties
You can choose to execute commands to change target properties by performing any of the following methods:
  • Navigating to the target, looking at its properties, and executing a command.
    For example, to set the HTTP user session time-out for the Oracle ILOM web server to 30 minutes, type:
    -> cd /SP/services/http
    /SP/services/http
    -> show
     /SP/services/http
        Targets:
        Properties:
           port = 80
           secureredirect = disabled
           servicestate = enabled
           sessiontimeout = 15
       Commands:
          cd
          set
          show
    -> set sessiontimeout=30
  • Entering the command and the full path to the target, from anywhere in the namespace, and changing a single property.
    For example:
    -> set /SP/services/http sessiontimeout=30
  • Entering the command and the full path to the target, from anywhere in the namespace, and changing multiple properties.
    For example:
    -> set /SP/services/http servicestate=disable secureredirect=enabled
Related Information
