Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 4.0.x
Exit Print View
Updated: September 2018
Executing Commands That Require Confirmation
For targets where a change in properties can interrupt current user sessions, configuration includes committing the pending change to take affect.
For example, changing the IP network settings for the SP in Oracle ILOM will cause an interruption to the current user sessions. Therefore, you will be required to commit any changes you have made to the IP properties before your changes can take affect in Oracle ILOM.
An example of the process used to commit changes for IP properties appears below:
  1. View the current network settings.
    -> show /SP/network
    /SP/network
       Targets:
          interconnect
          ipv6
          test
       Properties:
          commitpending = (Cannot show property)
          dhcp_clientid = none
          dhcp_server_ip = none
          ipaddress = 192.0.2.22
          ipdiscovery = static
          ipgateway = 192.0.2.1
          ipnetmask = 10.255.255.0
          macaddress = 00:28:25:E7:18:0C
          managementport = MGMT
          outofbandmacaddress = 00:28:25:E7:18:0C
          pendingipaddress = 192.0.2.22
          pendingipdiscovery = static
          pendingipgateway = 192.0.2.1
          pendingipnetmask = 10.255.255.0
          pendingmanagementport = MGMT
          sidebandmacaddress = 00:28:25:E7:18:0D
          state = enabled
       Commands:
          cd
          set
          show
  2. To change the settings, first enter the new (pending) information.
    ->set /SP/network pendingipdiscovery=static pendingipaddress=
    nnn.nn.nn.nn pendingipgateway=nnn.nn.nn.nn pendingipnetmask=nnn.nn.nn.nn
  3. Then, after you have confirmed that the new settings are correct, commit the new settings to have them take effect immediately:
    -> set /SP/network commitpending=true
Note -  You can also combine the commit property with the pending information in a single command.
Note - If you are connecting to Oracle ILOM over a LAN, you will have to reconnect to Oracle ILOM after committing any IP property changes.
Related Information
