Event ID |
Unique number used to identify
the encountered event. |
System Log
Event Log
Audit Log |
Date and Time |
Day and time the event occurred.
If the Network Time Protocol (NTP) server is enabled to set the Oracle
ILOM time, the Oracle ILOM clock uses Universal Coordinated Time
(UTC).
System Log
Event Log
Audit Log |
Event Type or Type |
Hardware dependent event
property.
Event type examples:
System Log
Event Log
Audit Log |
Subsystem |
Hardware dependent property
that identifies the subsystem where the event was encountered.
Subsystem examples:
System
Power
Cooling
Memory
Storage
I/O module
Processor
Blade
DCU
Firmware
Component |
that identifies the component where the event was encountered.
Component examples:
BLn (Blade n)
Hostn
/SYS (Host System)
CMUn (Processor Board n)
DCUn
PSn (Power Supply n)
Fann (Fan n)
Diskn
ILOM
Class |
that identifies the event class.
Class examples:
Audit/
Log – For commands that result in a configuration
change. Description includes user, command, command parameters,
and success/failure.
IPMI/Log – For any event that is recorded in the IPMI
SEL is also put in the management log.
Chassis/State – For
changes to the inventory and general system state.
Chassis/Action – For
shutdown events for server module/chassis, hot insert/removal of
FRU components, as well as Reset Parameters button when pushed.
Fault/Fault – Description
gives the time fault was detected and the suspect component name.
Fault/Repair – For
Fault Management repairs. Description gives component name.
Severity |
Severity level of the event.
Severity examples:
Debug
Down
Critical
Major
Minor
