Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 4.0.x
Exit Print View
Updated: September 2018
Network Requirements for Logging In
Before logging in to Oracle ILOM over a network connection, you must:
  • Establish a physical network management connection to the server SP or CMM from either an internal trusted network or a secure private network.
  • Obtain the network address assigned to the server SP or CMM.
    The accepted input formats for entering IPv4 and IPv6 addresses are as follows:
    Note -  When entering an IPv6 address or Link-Local IPv6 address, the address must be enclosed within brackets to work correctly. However, when you specify an IPv6 address to log in to Oracle ILOM using SSH, do not enclose the IPv6 address in brackets.
    • IPv4 address – 192.0.2.0
    • IPv6 address – [2001:db8:0:0:0:0:0:0/32]
    • IPv6 address using SSH and root user account – ssh root@[ipv6address]
    • Link-Local IPv6 address – [e80::214:4fff:feca:5f7e/64]
    • DNS host domain address – company.com
  • If you do not have an Oracle ILOM user account, you will need to obtain a user account from your Oracle ILOM system administrator.
Related Information
