Go to main content
Oracle® ILOM User's Guide for System Monitoring and Diagnostics Firmware Release 4.0.x
Exit Print View
Updated: September 2018
View and Clear Log Entries (CLI)
Oracle ILOM log entries for a host server or blade system chassis are viewable from the server SP CLI.
Before You Begin
  • Admin (a) role privileges are required to clear log entries.
To view and clear log entries using the server SP or CMM CLI, follow these steps:
  1. To view a tabular list of log entries, do one of the following:
    • For the system log, type:
      show /System/Log/list
    • For the event log, type either:
      show /SP/Logs/event/list
      or
      show /CMM/Logs/event/list
    • For the audit log, type either:
      show /SP/Logs/audit/list
      or
      show /CMM/Logs/audit/list
    To scroll through the list, press any key except the q key.
  2. To clear log entries shown, type set target clear=true command, and then type y at the prompt.
    For example:
    • set /System/Log clear=true
    • set /SP/logs/event/ clear=true
    • set /CMM/logs/event clear=true
    • set /SP/logs/audit clear=true
    • set /CMM/logs/audit clear=true
Related Information
