Skip Navigation Links
Exit Print View
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Gateway
Gateway Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Gateway
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber Data Cables
Route the Data Cables
Installing the Gateway
Install the Gateway in the Rack
Powering On the Gateway
Connecting Data cables
Administration
Troubleshooting the Gateway
Gateway Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Monitoring Gateway Resources
Controlling LAGs
Controlling VLANs and VNICs
Controlling Gateway Ports and Parameters
Remote Management
Understanding Oracle ILOM on the Gateway
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Gateway Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
SNMP Commands
V1 and V2c Protocol Command Format
V3 Protocol Command Format
Performing Daily Tasks (SNMP)
Display the Date and Time (SNMP)
Display the Time Zone (SNMP)
Display the Aggregate Sensors State (SNMP)
Display Power Supply Status (SNMP)
Display Board-Level Voltages (SNMP)
Display Internal Temperatures (SNMP)
Display Fan Status (SNMP)
Display the Sensor Alarm State (SNMP)
Display the Entity Numbers
Display Oracle ILOM Sessions (SNMP)
Display the Oracle ILOM Event Log (SNMP)
Checking the Status of Services (SNMP)
Display the HTTP Service Status (SNMP)
Display the HTTPS Service Status (SNMP)
Display the DNS Client Status (SNMP)
Display the SMTP Client Status (SNMP)
Display the NTP State (SNMP)
Display the NTP Servers (SNMP)
Verifying Other Aspects With Oracle ILOM (SNMP)
Display the Alert Properties (SNMP)
Display Oracle ILOM User Accounts (SNMP)
Display the Remote Log Hosts (SNMP)
Display the Network Management Configuration (SNMP)
Display Gateway FRU ID (SNMP)
Display Power Supply FRU ID (SNMP)
Display the System Components (SNMP)
Display the Additional System Component Information (SNMP)
Display the Firmware Version (SNMP)
Display System Identification Properties (SNMP)
Performing General Tasks (SNMP)
Set the Date and Time (SNMP)
Set the Time Zone (SNMP)
Set the Network Time Protocol State (SNMP)
Set the Network Time Protocol Servers (SNMP)
Clear the Oracle ILOM Event Log (SNMP)
Set the Remote Log Hosts (SNMP)
Configure the DNS Client (SNMP)
Configure the SMTP Client (SNMP)
Set the Network Parameters (SNMP)
Set the System Identification Properties (SNMP)
Performing User Tasks (SNMP)
Add an Oracle ILOM User Account (SNMP)
Delete an Oracle ILOM User Account (SNMP)
Managing Other Aspects With Oracle ILOM (SNMP)
Set the HTTP Service State (SNMP)
Set the HTTPS Service State (SNMP)
Enable Alerts to Send SNMP Traps (SNMP)
Enable Alerts to Send PETs (SNMP)
Enable Alerts to Send Email Alerts (SNMP)
Modify Alert SNMP Version (SNMP)
Disable Alerts (SNMP)
Administering Hardware (IPMI)
ipmitool Overview
Display Gateway Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Managing Faulty Components
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Evaluating Sensor Alarms
Accessing CLI Prompts
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Replace the Battery
Reference
addlagport Command
allowhostconfig Command
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
createlag Command
createvlan Command
createvnic Command
dcsport Command
delete_ipoib Command
deletelag Command
deletevlan Command
deletevnic Command
dellagport Command
disablecablelog Command
disablegwport Command
disablelagmode Command
disablelinklog Command
disablesm Command
disableswitchport Command
disablevnic Command
disallowhostconfig Command
enablecablelog Command
enablegwport Command
enablelagmode Command
enablelinklog Command
enablesm Command
enableswitchport Command
enablevnic Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
modifyvnic Command
setcontrolledhandover Command
setdefaultgwdiscpkey Command
setgwethport Command
setgwinstance Command
setgwsl Command
setgwsystemname Command
sethostvniclimit Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showgwconfig Command
showgwports Command
showioadapters Command
showlag Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
showvlan Command
showvnics Command
smconfigtest Command
smnodes Command
smpartition Command
smsubnetprotection Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
Note - The entity numbers used in this procedure are for example only. Your entity numbers might differ, depending on the gateway firmware and configuration. For more information about entity numbers, see Display the Entity Numbers.
Note - The fan speed values displayed for this procedure are in RPM.
  1. From the SNMP client, check for the presence of the fan.
    $ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatDiscreteSensorCurrent.number
    where number is the entity number for the /SYS/FANx/PRSNT presence sensor target for the respective fan. This example uses entity number 57 for the left fan (FAN1):
    $ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatDiscreteSensorCurrent.57
    SUN-PLATFORM-MIB::sunPlatDiscreteSensorCurrent.57 = INTEGER: 2
    In the output, the INTEGER: 2 means the fan is present. INTEGER: 1 means the fan is not present.
  2. Check the speed of the fan.
    $ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.number
    where number is the entity number for the /SYS/FANx/TACH speed sensor target for the respective fan. This example uses entity number 58 for the left fan (FAN1):
    $ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.58
    SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.58 = INTEGER: 12099
    The FAN1 speed displayed in the output of the example is 12099 RPM.
    Note - Fan speed readings can vary and are influenced by the gateway environment and loading.
  3. Check for a fault.
    where number is the entity number for the /SYS/FANx/FAULT sensor target for the respective fan. This example uses entity number 59 for the left fan (FAN1):
    $ snmpget -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatDiscreteSensorCurrent.59
    SUN-PLATFORM-MIB::sunPlatDiscreteSensorCurrent.59 = INTEGER: 1
    In the output, the INTEGER: 1 means State Deasserted, or there are no faults with the fan. INTEGER: 2 means State Asserted, or there is a fault with the fan.
  4. Display comprehensive fan information.
    $ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable
    SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.4 = INTEGER: volts(6)
    SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.6 = INTEGER: volts(6)
    SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.7 = INTEGER: volts(6)
    SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.8 = INTEGER: volts(6)
    SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.10 = INTEGER: volts(6)
    SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.58 = INTEGER: rpm(20)
    SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.62 = INTEGER: rpm(20)
    SUN-PLATFORM-MIB::sunPlatNumericSensorBaseUnits.66 = INTEGER: rpm(20)
    SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.58 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.62 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorExponent.66 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.58 = INTEGER: none(1)
    SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.62 = INTEGER: none(1)
    SUN-PLATFORM-MIB::sunPlatNumericSensorRateUnits.66 = INTEGER: none(1)
    SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.58 = INTEGER: 12208
    SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.62 = INTEGER: 11772
    SUN-PLATFORM-MIB::sunPlatNumericSensorCurrent.66 = INTEGER: 12099
    SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.58 = INTEGER: reset(1)
    SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.62 = INTEGER: reset(1)
    SUN-PLATFORM-MIB::sunPlatNumericSensorRestoreDefaultThresholds.66 = INTEGER: reset(1)
  5. Look though the output for the entity numbers respective to the fans.
    You can also filter the output of the snmpwalk command for a specific entity number. This is an example of filtering the snmpwalk command output.:
    $ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable |grep -F '.number ='
    where number is the entity number.
    Note - The manner in which you can filter the output varies according to your operating system.
    To filter speed information for the left fan (FAN1), use the entity number respective to the /SYS/FAN1/TACH speed sensor target. This filtering example uses entity number 58:
    $ snmpwalk -v2c -c public mc_IP SUN-PLATFORM-MIB::sunPlatNumericSensorTable |grep -F '.58 ='
    SUN-PLATFORM-MIB::sunPlatNumericSensorNormalMin.58 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorNormalMax.58 = INTEGER: 255
    SUN-PLATFORM-MIB::sunPlatNumericSensorAccuracy.58 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdNonCritical.58 = INTEGER: 6322
    SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdNonCritical.58 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdCritical.58 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdCritical.58 = INTEGER: 26705
    SUN-PLATFORM-MIB::sunPlatNumericSensorLowerThresholdFatal.58 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorUpperThresholdFatal.58 = INTEGER: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorHysteresis.58 = Gauge32: 0
    SUN-PLATFORM-MIB::sunPlatNumericSensorEnabledThresholds.58 = BITS: 90 lowerThresholdNonCritical(0) upperThresholdCritical(3)
Related Information
