Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Display the Subnet Manager's Location History
Display the Secret M_Key Configuration
Verify the Subnet Manager Configuration Integrity
Display the Subnet Manager Log
Set the Subnet Manager Priority
Enable Subnet Manager Controlled Handover
Set the Subnet Manager Readable Management Key
Clear the Subnet Manager Readable Management Key
Set the Subnet Manager Routing Algorithm
Configuring Secure Fabric Management
Prepare for Secret M_Key Functionality
Create the Secret M_Key Configuration
Add Secret M_Keys to the Configuration
Delete Secret M_Keys From the Configuration
Configure a Local Secret M_Key
Enable or Disable Secret M_Key Persistence
Enable or Disable Secret M_Key Functionality
Considering Situations In Regard to Secret M_Key
Add a New Subnet Manager to the Secret M_Key Fabric
Merge Subnets Into One Secret M_Key Fabric
Secret M_Key and Firmware Upgrade and Downgrade Guidelines
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
You can enable secret M_Key functionality using the smsubnetprotection command and its subcommands. The smsubnetprotection command is primarily issued from the gateway or switch that has the master Subnet Manager, and acts upon the secret M_Key configuration. There are two configurations, the active configuration is the one currently in use, and the modified configuration is the one which you can affect.
Configuring the secret M_Key consists of starting a configuration session adding or deleting M_Keys from the list, setting the current M_Key, and committing the list to active implementation. During the configuration session, you can also view the configuration list, undo your last action, or abort the configuration session altogether. If you will only add or only delete secret M_Keys from the list during the configuration session, you must initiate the session with the smsubnetprotection start -addonly or smsubnetprotection start -deleteonly command.
Note - You cannot both add and delete secret M_Keys within a single configuration session. You must perform these actions in separate configuration sessions.
The smsubnetprotection command can also enable and disable secret M_Key functionality, display the active M_Keys, set and clear the local secret M_Key for I4 switch chips without a corresponding Subnet Manager, and set the replication password.
