Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.1 |
Preparing to Install the Gateway
Assemble the Optical Fiber Data Cables
Install the Gateway in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Gateway
Display the Switch Chip Port to QSFP Connector Mapping
Locate a InfiniBand Device and Connector From the GUID and Port
Locate a Switch Chip or Connector From the GUID and Port
Display Switch Chip Boot Status
Display Connectors Configured With Autodisable Functionality
Display Switch Chip Port Status
Display Switch Chip Port Counters
Autodisabling Ports and Connectors
Add Connectors to the Autodisable List
Reenable Autodisabled Connectors
Delete Connectors From the Autodisable List
Configuring Secure Fabric Management
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Determine If the Battery Is Faulty
Remove the Gateway From the Rack
Switch chip ports and their connectors can be configured to automatically disable should their links exhibit high error rates or sub-optimal link speed or width. You use the autodisable command to add the connectors to the autodisable list, which has two parts; one for connectors whose links fail from high error rates, and another for connectors whose links fail from suboptimal link speed or width. A connector can be configured for both parts.
The autodisable feature monitors the following to determine if a connector and its respective link are experiencing high error rates:
SNMP traps
Oracle ILOM event log
Syslog
Email alerts
The autodisable feature also monitors the link speed and width, and if any of the following combinations are discovered, the link is considered suboptimal:
1x SDR
1x DDR
1x QDR
4x SDR
4x DDR
Note - If you intentionally configure a link for less than 4x QDR, do not add that connector to the link speed and width part of the autodisable list. It is automatically disabled.
Autodisable functionality is not enabled by default, you must actively configure it by adding connectors to the autodisable list. Additionally, you must actively monitor its operation and take corrective action if necessary. Failure to respond to autodisabled connectors and their links results in a degraded InfiniBand fabric.
Note - Because of its silent nature, have redundancy for autodisable configured links.
You can monitor autodisable configured connectors and their links using the listlinkup command or the Fabric Monitor. For both interfaces, a connector which has been autodisabled is identified with the text AutomaticHighErrorRate, AutomaticBadSpeedOrWidth, or both.
Removing a connector from the autodisable list stops autodisable functionality for that connector and its link. However, it does not re-enable an autodisabled connector or its link. You must investigate the condition of the disabled cable and connector and replace it if necessary. You can then re-enable an autodisabled connector with the --automatic option of the enableswitchport command.
Gateway Reference, autodisable command
Gateway Reference, enableswitchport command
Gateway Service, servicing cables
