Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1 |
InfiniBand QSFP Connector and Pins
Understanding InfiniBand Cabling
Preparing to Install the Switch
Assemble the Optical Fiber InfiniBand Cables
Install the Switch in the Rack
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Configuring Secure Fabric Management
Understanding Oracle ILOM on the Switch
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Determine If a Power Supply Is Faulty
Inspecting the InfiniBand Cables
Determine If the Battery Is Faulty
Remove the Switch From the Rack
SUN-DCS-IB-MIB MIB OID Command Syntax
Subnet Manager Agent Data Port OIDs
Understanding Performance Manager Agent OIDs
PMA Extended Port Counters Table OIDs
SUN-FABRIC-MIB MIB OID Command Syntax
Fabric Management Element OIDs
Fabric Management External Element OIDs
Fabric Trap Configuration OIDs
Hardware Trap Configuration OIDs
SUN-ILOM-CONTROL-MIB MIB OID Command Syntax
SUN-PLATFORM-MIB MIB OID Command Syntax
Understanding MIB Physical OIDs
Sun Platform Sensor Table OIDs
Sun Platform Numeric Sensor Table OIDs
Understanding the ENTITY-MIB MIB OIDs
This table lists physical class extension object identifiers supported by the SUN-PLATFORM-MIB MIB.
