Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
InfiniBand QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding InfiniBand Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber InfiniBand Cables
Route the InfiniBand Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting InfiniBand cables
Administration
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring Secure Fabric Management
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Managing Faulty Components
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Evaluating Sensor Alarms
Accessing CLI Prompts
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing InfiniBand Cables
Inspecting the InfiniBand Cables
Remove an InfiniBand Cable
Install an InfiniBand Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Replace the Battery
Reference
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
dcsport Command
delete_ipoib Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
smsubnetprotection Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
SUN-DCS-IB-MIB MIB OID Command Syntax
Enclosure OIDs
Enclosure Nodes OIDs
Neighbor Node OIDs
Subnet Manager Info OIDs
Subnet Manager Agent Data Port OIDs
Understanding Performance Manager Agent OIDs
PMA Port Counters Table OIDs
PMA Extended Port Counters Table OIDs
Understanding SNMP Trap OIDs
Trap Control OIDs
Trap Threshold OIDs
Trap Notification OIDs
IB Trap OIDs
SUN-FABRIC-MIB MIB OID Command Syntax
Fabric Element OIDs
Fabric Management OIDs
Fabric Management Element OIDs
Fabric Management External Element OIDs
Fabric Management Link OIDs
Fabric Trap Configuration OIDs
Hardware Trap Configuration OIDs
Hardware Traps
Hardware Fault Traps
SUN-ILOM-CONTROL-MIB MIB OID Command Syntax
NTP OIDs
Remote Syslog OIDs
HTTP OIDs
HTTPS OIDs
Network OIDs
User OIDs
Session OIDs
Event Log OIDs
Alert OIDs
Clock OIDs
Backup and Restore OIDs
Identification OIDs
SMTP OIDs
DNS OIDs
SUN-PLATFORM-MIB MIB OID Command Syntax
Understanding MIB Physical OIDs
High-Level OIDs
NIM Equipment Table OIDs
Physical Class Extension Table OIDs
Sun Platform Sensor Table OIDs
Sun Platform Numeric Sensor Table OIDs
Discrete Sensor Table OIDs
Sun Platform Fan Table OIDs
Sun Platform Alarm Table OIDs
Understanding the ENTITY-MIB MIB OIDs
ENTITY-MIB MIB OID Command Syntax
Physical Entity Table OIDs
Index
Fabric Element OIDs
This table lists fabric element object identifiers supported by the SUN-FABRIC-MIB MIB.
Description of Task or Activity
Action
MIB OID
Display the host name and IP address of the fabric element.
read
fabricElemName
Display the product name of a fabric element.
read
fabricElemType
Display the current aggregated operational state of the fabric element.
read
fabricElemOperStatus
Display the IP address of the fabric manager.
read
fabricElemMgrIpAddress
Display whether the fabric manager is currently available to the fabric element.
read
fabricElemMgrAlive
Display the type of fabric the element supports (InfiniBand or Ethernet).
read
fabricElemFabType
Display the number of logical ports the element supports.
read
fabricElemNumPorts
Display a table of information about the logical ports associated with a specific fabric element.
read
fabricElemPortTable
Display information about a specific fabric element.
read
fabricElemPortEntry
Display an integer which uniquely identifies the instance among all of the fabric element's port instances.
read
fabricElemPortIndex
Display the logical port identifier for the fabric element.
read
fabricElemPortID
Display the status for the specific port.
read
fabricElemPortOperStatus
Display the physical address of neighbor/remote elements. For Ethernet it is the MAC address, for IB it is the GUID + port.
read
fabricElemPortRemAddr
Display the ID of the connector table entry associated with the fabric element.
read
fabricElemPortConnID
Display the fabric element port's position in the connector. For single port connectors, the position is always 1.
read
fabricElemPortConnPosition
Display the physical address associated with the local port. For Ethernet it is the MAC address, for InfiniBand it is the GUID + port.
read
fabricElemPortLocalAddr
Display the number of connectors in the connector table.
read
fabricElemNumConnectors
Display a table of information about the physical connectors associated with a specific fabric element.
read
fabricElemConnectorTable
Display information about a specific fabric element's connector.
read
fabricElemConnEntry
Display an integer which uniquely identifies the instance among all of the fabric element's connector instances.
read
fabricElemConnIndex
Display the connector type. The types are:
  • cable based - QSFP, CXP, SFP, and so on
  • chassis/backplane based
  • chip to chip connections
read
fabricElemConnType
Display the network type supported by the connector.
read
fabricElemConnNetworkType
Display the number of ports associated with the connector.
read
fabricElemConnNumPorts
Display the connector position in the fabric enclosure.
read
fabricElemConnDescr
Display the identifier for the line card associated with the connector.
read
fabricElemConnCardNum
Display the identifier for the connector.
read
fabricElemConnID
Display the roles assigned to the fabric element.
read
fabricElemRoles
Display the datacenter positional information (x coordinate).
read
fabricElemRackPosX
Display the datacenter positional information (y coordinate).
read
fabricElemRackPosY
Display the datacenter positional information (z coordinate). This coordinate is also the position within the rack.
read
fabricElemRackPosZ
Related Information
