Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.1
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Access to Oracle Support
Installation
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
NET MGT Connector and Pins
InfiniBand QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding InfiniBand Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Assemble the Optical Fiber InfiniBand Cables
Route the InfiniBand Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting InfiniBand cables
Administration
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Network Management Troubleshooting Guidelines
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Oracle ILOM Command Overview
Hardware Command Overview
InfiniBand Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring Secure Fabric Management
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
CLI Overview
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (Oracle ILOM)
help Command (Oracle ILOM)
load Command
reset Command
set Command
show Command
version Command (Oracle ILOM)
Service
Detecting and Managing Faults
Interpreting Status LEDs
Managing Faulty Components
Identify Faults in the Oracle ILOM Event Log
Determining the Alarm State of a Component or System
Evaluating Sensor Alarms
Accessing CLI Prompts
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Determine If a Power Supply Is Faulty
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Determine If a Fan Is Faulty
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing InfiniBand Cables
Inspecting the InfiniBand Cables
Remove an InfiniBand Cable
Install an InfiniBand Cable
Servicing the Battery
Determine If the Battery Is Faulty
Remove the Switch From the Rack
Replace the Battery
Reference
autodisable Command
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
create_ipoib Command
createfabric Command
dcsport Command
delete_ipoib Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportcounters Command
getportstatus Command
help Command (Hardware)
listlinkup Command
localmkeypersistence Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsmrouting Command
setsubnetprefix Command
showdisk Command
showfree Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
smsubnetprotection Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
SUN-DCS-IB-MIB MIB OID Command Syntax
Enclosure OIDs
Enclosure Nodes OIDs
Neighbor Node OIDs
Subnet Manager Info OIDs
Subnet Manager Agent Data Port OIDs
Understanding Performance Manager Agent OIDs
PMA Port Counters Table OIDs
PMA Extended Port Counters Table OIDs
Understanding SNMP Trap OIDs
Trap Control OIDs
Trap Threshold OIDs
Trap Notification OIDs
IB Trap OIDs
SUN-FABRIC-MIB MIB OID Command Syntax
Fabric Element OIDs
Fabric Management OIDs
Fabric Management Element OIDs
Fabric Management External Element OIDs
Fabric Management Link OIDs
Fabric Trap Configuration OIDs
Hardware Trap Configuration OIDs
Hardware Traps
Hardware Fault Traps
SUN-ILOM-CONTROL-MIB MIB OID Command Syntax
NTP OIDs
Remote Syslog OIDs
HTTP OIDs
HTTPS OIDs
Network OIDs
User OIDs
Session OIDs
Event Log OIDs
Alert OIDs
Clock OIDs
Backup and Restore OIDs
Identification OIDs
SMTP OIDs
DNS OIDs
SUN-PLATFORM-MIB MIB OID Command Syntax
Understanding MIB Physical OIDs
High-Level OIDs
NIM Equipment Table OIDs
Physical Class Extension Table OIDs
Sun Platform Sensor Table OIDs
Sun Platform Numeric Sensor Table OIDs
Discrete Sensor Table OIDs
Sun Platform Fan Table OIDs
Sun Platform Alarm Table OIDs
Understanding the ENTITY-MIB MIB OIDs
ENTITY-MIB MIB OID Command Syntax
Physical Entity Table OIDs
Index
This table lists trap notification object identifiers supported by the SUN-DCS-IB-MIB MIB.
Description of Task or Activity
Action
MIB OID
Display an index of InfiniBand nodes originating a trap.
read
ibSnmpTrapNodeIndex
Display an index of InfiniBand data ports originating a trap.
read
ibSnmpTrapPortIndex
Display the performance counter causing a trap.
read
ibSnmpTrapPerfErrCounter
Display the counter value causing a trap.
read
ibSnmpTrapCounterVal
Display a mapping of SNMP InfiniBand device port to connector causing a trap.
read
ibSnmpTrapPortConnector
Identify the master Subnet Manager causing a trap.
read
ibSnmpTrapMasterSMPresent
Display the LID of the master Subnet Manager of a trap.
read
ibSnmpTrapMasterSMLid
Display the currently active link width of a trap.
read
ibSnmpTrapLinkWidthActive
Display the state of the link on the port of a trap.
read
ibSnmpTrapLinkState
Display the currently active link speed of a trap.
read
ibSnmpTrapLinkSpeedActive
Display the GUID of the trap's node.
read
ibSnmpTrapNodeGuid
Display the LID of the trap's node.
read
ibSnmpTrapNodeLid
Display the NodeDescription of the trap's node.
read
ibSnmpTrapNodeDescr
Display how much the symbol error counter increased during the error rate monitoring interval.
read
ibSnmpSymErrIncrease
Display and set the error rate monitoring interval.
read
write
ibSnmpErrRateInterval
Display a description of what requires attention.
read
ibSnmpAttDecription
Display the perceived severity of the issue requiring attention.
read
ibSnmpAttSeverity
Display the probable cause of the issue requiring attention.
read
ibSnmpAttProbableCause
Display the repair action for the issue requiring attention.
read
ibSnmpAttRepairAction
Related Information
