Caution - Running the Oracle Fabric OS configuration wizard destroys preconfigured data. If you are manually running the wizard, consider backing up configuration data before proceeding. |
The Oracle Fabric OS configuration wizard runs the first time the switch is started, or after each time the system configuration is reset or cleared. To run the Oracle Fabric OS configuration wizard, you must be in the Oracle ILOM to access the SCP through the host console.
For more information, refer to Access the Oracle Fabric OS in Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide.
[OFOS} system clear config This is a destructive operation. Your configuration will be cleared and the system will be restarted. Please type 'confirm' to clear the configuration and restart the system. > confirm
Then log in to the Oracle Fabric OS again.
Type Y.
When completed, the wizard reboots the Oracle Fabric OS.
See:
