Would you like to use the OFOS Configuration Wizard?
Yes/No
What is the switch's host name?
alphanumeric string
What is the domain for the switch?
alphanumeric string
Do you want to enable a strong password configuration?
Yes/No
If yes, what is the minimum number of characters in the
password?
1 - 8
Zero bypasses the parameter.
If yes, what is the minimum number of lower case letters in the
password?
1 - 8
If yes, what is the minimum number of digits in the
password?
1 - 8
If yes, what is the minimum number of special characters in the
password?
1 - 8
If yes, what is the minimum number of upper case letters in the
password?
1 - 8
What is the password for the root
user?
Note -
This password will also be used to log into Oracle Fabric
Manager.
alphanumeric string, which must comply with strong password
parameters (if configured).
What is the password for the admin
user?
Note -
This password will also be used to manage the switch from
within Oracle Fabric Manager.
What IP address type will be used for the switch ?
Static/DHCP
What is the switch management address?
IP address in dotted decimal notation.
What is the switch's subnet mask?
Subnet mask in dotted decimal notation.
What is the switch's default gateway?
What are the switch's DNS server address(es)?
What is the switch's timezone?
Tab through to choose from displayed.
What is the chassis MAC address?
Note -
MAC addresses must be unique for each switch for vNICs to
operate correctly.
Choose from displayed, or enter specific private MAC address.
