Connect the RJ-45 Ethernet Cables
Use this procedure to connect RJ-45 cables to an Oracle F2 Quad Port 10GBASE-T I/O
module as well as to the switch chassis.
Identify the prerequisite and subsequent installation tasks that you must
perform in conjunction with this task.
See Installation Task Overview.
Orient the RJ-45 connector to where it will connect to the switch.
For the chassis, the tab on the connector is up.
For the Oracle F2 Quad Port 10GBASE-T module, the tab on the connector is to
the right.
Insert the connector into the receptacle until it clicks, securing it in
place.
Lay the cable into a slot on the cable management comb.
Repeat Step 2 and
Step 3 for each
cable to be connected.
Consider your next task.
