The following known issues exist at the time of this release.
SLB-L2 Error is Seen When Reassigning a Port From One LBG Group to Another (7100720)
SLB Must Not Allow Different VLANs in the Same Group (7095155)
SLB L2 Cannot Create More Than Two Groups, SLB L2 Limits to Two LBGs (7092380)
Manually Deleting Static Route Does Not Affect the Corresponding SLB Entry (7064092)
Changing the Default Value for default-vlan-id Could Result in VLAN Misconfiguration (7015004)
Some of the IGMP Conformance Results Don't Match Expectations (7006297 and 6997415)
QoS - set algo-type tailDrop queue-drop-algo Does Not Work (6991230)
Packets Might Be Dropped When Using Q-in-Q Interop in Certain Configurations (6989048)
The no default-metric [,short(1-16)>] Command Does Not Work as Documented (6987482)
CMM Reports SAS2 on the NEM as Faulty if SAS2 Is Not Enabled (6977266)
Using vlan 1 as Shown in Various Examples in the Documentation Generates Error Codes (6968484)
When Multiple Configuration Scripts Are Run in Parallel, SEFOS Application Can Crash (6936742)
