The no default-metric [,short(1-16)>] Command
Does Not Work as Documented (6987482)
Workaround: Ignore the
keyword short when it appears in the syntax of
any command and execute the command without it. Using this CR's
synopsis as an example, the command is issued as no default-metric
1.
