Workaround: If you need to change default-vlan-id from 1 (the default value) to some other value, you must do so before doing any other VLAN configuration. When using XVLAN features, only default-vlan-id 1 is supported. In order to use the XVLAN feature, you must restore the default value of 1 for default-vlan-id if it was changed.
