address [tacacs+_server_IP_address] |
0.0.0.0 |
Specifies the IP address or DNS name
of the TACACS+ server. If you use DNS, ensure that DNS is configured
and functional. |
Defaultrole [a|u|o|c|r|s|Administrator|Operator] |
Operator |
Specifies the access role that is granted
to all authenticated TACACS+ users.
This property supports the following legacy roles:
Administrator
Operator
Any individual role ID combinations where a =
Admin, u = User Management, o =
Operator, c = Console, r =
Reset and Host Control, and s = Service.
fs_privilege [1|15] |
1 |
Specifies the fs_privilege that
is used for TACACS+ authenticated users to access and control SEFOS. |
port [port_number] |
49 |
Specifies the port number used to communicate
with the TACACS+ server. |
protocol
service |
ip
ppp |
protocol identifies
the TACACS+ protocol type. service identifies
the TACACS+ service type. (see footnote)
In the TACACS+ server, the combination of ppp and ip can
be configured to send additional fields in packet data. For Oracle
ILOM clients this is used to send Oracle ILOM-specific fields like sefos-fs-privilege and ilom-role. |
secret [tacacs+_secret] |
[none] |
Specifies the shared secret that is used
to protect sensitive data and to ensure that the client and server
recognize each other. |
state [enabled|disabled] |
Disabled |
Specifies whether the TACACS+ client
is enabled or disabled. |
