These limitations apply to the NEM when installed in a Sun Blade 6000 modular system or Sun Netra 6000 modular system chassis.
This NEM cannot be installed in a modular system chassis with any other type of NEM. If any other type of NEM is installed in a modular system chassis, remove those NEMs before installing this NEM.
External SAS2 ports are not supported. Only the internal SAS2 links with appropriate REM and storage modules are supported. See Enabling SAS2 Functionality for more information.
In NEBS environments, only optical links to QSFP ports of this NEM are supported. Using optical links ensures that NEBS thermal limits are met.
