For more information, refer to the Sun Blade 6000 Ethernet Switched NEM 24p 10GbE User's Guide.
SEFOS# exit -> reset /SP Are you sure you want to reset /SP y Performing reset on /SP
The firmware image file is Sun_Blade_6000_Ethernet_Switched_NEM_24p_10GE_sefos-1_2_2_15.pkg.
This example illustrates the NEM upgrade process using FTP from a server with an IP address of 192.168.1.100.
-> load -source ftp://username:password@192.168.1.100/Sun_Blade_6000_Ethernet_Switched_NEM_24p_10GE_sefos-1_2_2_15.pkg Downloading firmware image. This will take several minutes. ... NOTE: An upgrade takes about 6 minutes to complete. ILOM will enter a special mode to load new firmware. No other tasks can be performed in ILOM until the firmware upgrade is complete and ILOM is reset. Are you sure you want to load the specified file (y/n)? y Preserve existing configuration (y/n)? y Starting FW upgrade. This will take approximately 3 minutes. Checking "jffs2 root file system image" Starting Root File System upgrade Upgrading Root File System image to partition 2 ................................................................ ................................................................ ................................................................ ................................................................ Validating File System and updating Time Stamp. This will take 2-3 minutes, please wait. Checking "compressed kernel image" Starting kernel upgrade Upgrading kernel image to partition 2 ....... Syncing configuration files. .................................... Checking "FPGA image" Starting FPGA upgrade Skip upgrading FPGA (same version). Checking "U-Boot image" Starting U-Boot upgrade Skip upgrading U-Boot (same version). Firmware update is complete. The system must be reset for the new image to be loaded -> reset /SP Are you sure you want to reset /SP (y/n)? y Performing reset on /SP
If the upgrade was done while in ONET mode, you must explicitly restart ONET from Oracle ILOM after the upgrade as follows:
-> start /NEM/onet Are you sure you want to start /NEM/onet (y/n)? y start: start: Please wait while onet comes up, this can take anywhere from 30 seconds to 2 minutes depending on the configuration ........................ start: ONET Enabled successfully.
-> cd /NEM/fs_cli/ cd: Connecting to Fabric Switch CLI ORACLESP-0110SJC-0938CB0081 SEFOS# show system information Hardware Version : 2.5.8_00209384 Firmware Version : ONEM- Switch Name : C10 NEM 24P System Contact : System Location : Logging Option : Console Logging Login Authentication Mode : Local Config Save Status : Not Initiated Remote Save Status : Not Initiated Config Restore Status : Not Initiated
