Include the SEFOS Configuration
in Backups
By default, only the Oracle ILOM configuration
is backed up when the backup feature is used. Complete the following
tasks to include the SEFOS configuration in this backup.
- Before
backing up your SEFOS configuration using the Oracle ILOM backup feature,
complete the following steps:
- Save the NEM configuration.
SEFOS# write startup-config
Building configuration ...
[OK]
- Set a passphrase.
-> cd /SP/config
/SP/config
-> set passphrase=abc123
Set 'passphrase' to 'abc123'
Note - The passphrase you provide must not contain the @, ‘
(apostrophe), " (quotes), or \ (back slash) symbols.
- Ensure that you have proper login
credentials for the server where the configuration is to be backed
up.
- Back up the configuration to
remote server.
-> set dump_uri=ftp://username:password@192.168.1.100/tmp/myNEMconfig.bak
Dump successful
