21445917
Fix for CVE-2015-1793.
20440855
CVE-2015-0235 - "GHOST" Vulnerability in GLIBC
19888525 |
Provide support for LLA feature on NEM. |
19884205 |
Please provide link-trailing feature |
19689330 |
Apply fixes for BASH software threat:
CVE-2014-7169 / CVE-2014-6271 |
18976705 |
CVE-2014-0224 ETC, MULTIPLE SECURITY
BUGS - UPGRADE OPENSSL |
18756094 |
Missing "#" in CLI Prompt |
18391504 |
Enhance the CLI to clear dynamic MAC
addresses globally, per-VLAN, and per-interface. |
18391464 |
RIP: Triggered updates are sent from
a passive interface. |
18383281 |
NEM restarts due to memory shortage. |
18291821 |
LDAPSSL, RADIUS, and TACACS+ client password
authentication fails on even numbered occurrences of the password
prompt. |
18262738 |
root user login
without password is possible when TACACS+ authentication is configured. |
18118742 |
Unclean shutdown of the diagnostics does
not release buffers/lock, can block Rx/Tx. |
18118577 |
VLAN name cannot be specified for a new
VLAN in PVRST mode. |
18038564 |
Display CPU, memory, and disk usage from
Oracle ILOM CLI. |
18038543 |
Display host name in an Oracle ILOM prompt. |
18038361 |
Copy SEFOS files from Oracle ILOM. |
18038350 |
Implement reset for /SYS/sefos. |
18038336 |
IPV6: ND/RA packets only get trapped
to CPU and do not get switched to other ports. |
18038328 |
show debugging 2019 command
always shows output OSPF3 - Critical debugging is on. |
18038322 |
debug npapi command:
Added Rx and Tx packet dump options. |
18038311 |
When applying ACL to block RA from source
server it blocks all ICMP. |
18038285 |
Support for multiple RADIUS servers. |
18038275 |
Support for multiple TACACS+ servers. |
17943395 |
NEM configuration is not restored after
a power failure. |
16239036 |
fs_privilege accepts
extra nonnumerical characters after valid value. |
17435862 |
A session's state is not cleaned up in
SEFOS when remotely authenticated sessions exit. |
17435883 |
Remotely authenticated user removed from
SEFOS prematurely. |
17435892 |
QSFP MMF transceiver and QSFP Cu Twinax
cables are not recognized by SEFOS. |
17435909 |
Dynamic MAC entries of the port do not
get flushed on STP status change. |
17435930 |
The port-channel state might not get
reflected correctly by the show ether summary command. |
17435949 |
Ping to broadcast IP fails over NEM. |
7128865 |
1.2.1 IPv6 PMTU is restored after reboot. |
7101943 |
1.2.1 shutdown opus interface does not
cause nxge to show link down messages. |
7096178 |
ACLv6 permit/deny combination is not
blocking traffic. |
7128877 |
ONEM does not return to ONET mode after
reset. |
7116342 |
SEFOS/ONET needs to be started after
upgrading firmware in ONET mode and resetting SP. |
7116607 |
SNMP error messages display wrong OID. |
7100720 |
SLB L2: Error is seen when re-assigning
a port from one LBG group to another. |
7153553 |
Allow special characters to be included
in the VLAN name. |
2221780 |
XVLAN port delete is not handled correctly. |
7152313 |
Watchdog exception on ONEM after shutting
down Cisco 6509 port. |
2221270 |
Add L3 functionality to XVLAN interfaces. |
7174488 |
STP: Need to support the loop guard. |
7167700 |
ONEM link doesn't come up after repetitive
shut/no shut. |
2222974 |
Allow debug print prior to debug thread
start. |
7174466 |
ping ipv4: Add ping command
options to accept source as VLAN ID or IP address. |
7174467 |
set port gvrp disable:
Gobal gvrp disabled, but still needs to
disable it on interface. |
7007423 |
Incorrect message seen when assigning
ports to port-channel repeatedly. |
7042329 |
Save important log files so they exist
even after a reset /SP command. |
7174501 |
Better error message needed when fs_cli cannot
be started. |
7174602 |
Show CRC counters. |
7174820 |
Do not show repeated history. |
7174823 |
Use Oracle ILOM source for NTPD. |
2221780 |
2221270 |
7035740 |
Implement TACACS+ access control. |
7187305 |
RIP with MD5 authentication: Keychain
value is not preserved after save and reboot. |
7187304 |
RIP with 2k routes: Not learning all
the routes from the neighbor, and crashing after a while. |
7184848 |
XVLAN+RIP: Route is not distributed or
learned after save and reboot. |
7179258 |
Issue with spanning-tree
mst forward-time, spanning-tree mst max-age. |
7187210 |
STP: MSTP port role and state not converged
correctly during failover testing. |
7206488 |
SLB: failover does not happen when standby
node is available again. |
7179564 |
7186136 |
Make switch uptime and SEFOS uptime visible
from Oracle ILOM. |
7207591 |
SEFOS restarts with PVRST config. |
2198812 |
SEFOS MIB access is lost due to the Agentx
subagent dropping packets. |
6899100 |
Garbage characters are displayed with
backspace key at the login prompt. |
6985493 |
64-bit counters in the interface MIB
are not working. |
7004715 |
SEFOS audit log events should be routed
to Oracle ILOM. |
7004717 |
Add cron job to allow
log rotation. |
7007791 |
Route entry may not be added to a ECMP
group when the next hop addresses are already resolved. |
7015496 |
Restore of SNMP community fails. |
7019251 |
Port speed change does not get saved
across reboots if the port is a member of any LAG. |
7020153 |
RADIUS default role is not preserved
across a reboot. |
7022286 |
Syslog target IP address is not preserved
when upgrading firmware. |
7029161 |
Make hostname part of SEFOS prompt. |
7029946 |
[A-00002871][F-4746] IPv4/IPv6 static
route is unstable after upgrade.
This fix requires you to recreate your configuration from
scratch before installing the 1.1.0.11. firmware. |
7030829 |
Routed traffic is trapped when multicast
is shut down. |
7033812 |
Advertise hostname as system name in
LLDP. |
7035245 |
Audit log should not display SEFOS passwords. |
7036831 |
Debug messages on the console are misaligned. |
7038044 |
RADIUS: Local root user
is not able to get into SEFOS. |
7039468 |
Protect SEFOS special users. |
7040207 |
MAC learning is inconsistent across LAG
(SDK 2.5.8). |
7042329 |
even after a reset /SP command is issued. |
7043345 |
Debug messages are truncated to 80 bytes. |
7043692 |
SEFOS shutdown task sometimes hang forever. |
7043940 |
Increase maximum size of debug log file. |
7046128 |
cd /NEM/fs_cli accepts
characters after the command without reporting an error. |
7046583 |
RADIUS root user
can stop/start SEFOS. |
7046586 |
When logging in as local user with role=s the
switch reports Unable to set session remote IP address. |
7056299 |
SEFOS is not sending a trap when CPU
utilization exceeds the maximum threshold. |
7058695 |
Port-channel sometimes can not establish
connections. |
7067339 |
SEFOS can not Restore if more than 10
IP addresses are used |
7069057 |
IP route is missing for some VLANs and
breaks connectivity. |
7072399 |
Enable XVLAN/VLAN port sharing. |
7078601 |
RIP packets should not be trapped if
the RIP feature is disabled. |
7080854 |
Creating a user with the string password displays
an internal password in Oracle ILOM. |
7080860 |
Unable to create a user in Oracle ILOM
starting with the string password. |
7092642 |
Static route sometimes not saved or restored
correctly. |
7097788 |
Protocol packets on port-channels use
out of range MAC addresses. |
7098864 |
SEFOS is not showing all PIMv4 neighbors. |
7110231 |
VLAN: Problem in adding VLAN entries
after a save or reboot. |
7100755 |
IP RIP authentication mode MD5 causes
some routing tables not to sync or update. |
2213237 |
Bad values are returned in the SEFOS
MIB. |
6872119 |
The output of the show interfaces int counters command
is not aligned. |
6885891 |
Disable the service account by default. |
6899100 |
Unnecessary characters are displayed
with use of the backspace key at the login prompt on the console. |
6901521 |
Untagged ports can show up on the default
VLAN as well as where they are actually assigned. |
6916366 |
Re-enable PVRST+. |
6920781 |
Make Oracle ILOM enterprise MIBs available
on standard SNMP ports. |
6920407 |
SNMP request for unsupported feature
MIB should not return resourceUnavailable message. |
6943438 |
SNMP agent doesn't invoke the MIB handlers
for Sun enterprise OIDs greater than 231. |
6947266 |
ILOM backup and restore feature should
support switch configuration files as well. |
6951536 |
Add the ability to set fs_privilege attribute
from the web browser. |
6952228 |
Allow SEFOS to be stopped or started
without a reboot. |
6962823 |
Upgrading switch firmware from 1.0.1.6
to version 1.1.0.0 through the web browser fails. |
6964907 |
64-bit counters in interface MIB are
not working. |
6966581 |
Oracle ILOM restore from the telnet console
restarts the session and the user can't login again. |
6966772 |
Oracle ILOM restore from BUI restarts
the session and user can't login again. |
6970627 |
Enable Oracle ILOM advanced user authentication
methods (RADIUS, etc.) |
6972856 |
running-config shows
different interface type for port mirror monitor session configure. |
6973258 |
QoS: Weight is incorrectly calculated. |
6979262 |
Reduce writes to flash file system by
moving /var and /tmp to tmpfs. |
6979532 |
ServiceTag should use the swordfish UUID
rather than the part number. |
6980869 |
The create user password=password command
does not create the fs_privilege attribute. |
6985379 |
Enable DNS. |
6985524 |
SEFOS MIB access is lost due to the agentx
6985910 |
Ping fails, the switch drops ICMP echo
reply packets. |
6987118 |
Re-setting the same serial port configuration
from the console causes the session to close. |
6987319 |
Traffic is not what is expected when
MTU is set to 1500 bytes. |
6988059 |
SSH v2 should be the only version in
Oracle ILOM for the switch. |
6988496 |
Assigning a port to a VLAN does not remove
the port as a member of VLAN 1. |
6989048 |
Packets might be dropped when using Q-in-Q
interoperability in certain configurations. |
6990073 |
The NEM SP does not blink the OK LED
while the SP is booting. |
6993233 |
MIB files are missing for OSPF and some
bridge OIDs. |
6994749 |
The help password command
shows some unnecessary characters. |
6994852 |
Disabling ServiceTag doesn't close ServiceTag
Listener port. |
6994875 |
Issue with stop /NEM/fs_cli and stop /NEM/sefos. |
6991712 |
The switch crashes when changing mtu
size. |
6992172 |
CLI - The switch's CLI does not have
any commands to show counter and packet types for a queue. |
6992476 |
Cannot login to Oracle ILOM. |
6993232 |
Enable Agentx to forward OIDs originating
from SEFOS. |
6993286 |
User login name and login prompt are
capitalized. |
6993669 |
QOS: set meter command
does not work with some parameters. |
6993790 |
Email-alert is not working. |
6994351 |
When a RADIUS user has an Oracle ILOM
role of aucr, the show command
in Oracle ILOM does not work properly on the switch. |
6996351 |
Need the remote IP address to be included
in Oracle ILOM logging. |
6997619 |
Multiple administrators configuring the
switch at the same time can generate a bad configuration file. |
6998458 |
Disabling SNMP can hang Oracle ILOM. |
6999896 |
Events are not generated for fan faults. |
7000727 |
Unexpected carriage return is added at
end of the 1st line when displayed data spans 2 console lines. |
7001228 |
Timezone changes are not reflected in
SEFOS without restart. |
7002324 |
QoS: set meter command
failed. |
7004641 |
The console connection should always
be available. |
7005015 |
The switch fails to power on during hot
plug test. |
7008862 |
The port-channel configuration is incompatible
with range mode. |
7014291 |
Change SEFOS incremental save SW default
to disabled. |
7030305 |
IP ACLs block ARP. |
7030991 |
Make hostname part of the SEFOS prompt. |
7057085 |
Add an option to show VLANs in ascending
order (new token: show VLAN ascending). |
7068895 |
NEM0 hung and required power cycling
to recover. Configuration was lost. |
7078601 |
7082585 |
PVRST+: Remove unused tokens. |
7082599 |
SEFOS: Disable the hardware flow control
by default. |
