Restore the Configuration
Note - The administrator must always reset the
SNMP engine ID prior to doing the backup or restore operation. Because
of CR 6934622, the SNMP engine ID (even when previously set) is
not visible after a reset of the system, and the administrator must record
and set the ID explicitly.
- Configure
the network settings on the Oracle ILOM network management interface
to communicate with the backup server.
-> cd /SP/network
- Set the passphrase to the same
value that was used for backup.
See Include the SEFOS Configuration in Backups.
-> cd /SP/config
/SP/config
-> set passphrase=abc123
Set 'passphrase' to 'abc123'
- Restore the configuration from
the server.
-> set load_uri=ftp://username:password@192.168.1.100/tmp/myNEMconfig.bak
Load successful.
Note - If DHCP is used for network configuration, the DNS setting
is overwritten with values supplied by the DHCP server upon restoration.
Note - If a syslog server address was configured in Oracle
ILOM, the address is not retained when upgrading from the 1.1.0.x release
(see CR 7022286). The syslog server setting must be reconfigured
after the upgrade or restore.
