TACACS+
TACACS+ (Terminal Access Controller Access-Control System Plus) is an access control protocol for routers, network access servers, and other networked computing devices. TACACS+ provides separate authentication, authorization and accounting services. See Configuring TACACS+.
LDAP and LDAP over SSL
Oracle ILOM supports LDAP authentication for users, based on the OpenLDAP software. LDAP is a general-purpose directory service. A directory service is a centralized database for distributed applications designed to manage the entries in a directory. Thus, multiple applications can share a single-user database. LDAP over SSL offers enhanced security to LDAP users by way of SSL technology.
SAS2
The SAS2 feature that was delivered in the 1.1 release of this switch can now be enabled or disabled from the Oracle ILOM CLI. See Enable or Disable SAS2 From Oracle ILOM.
Oracle ILOM
Banner configuration support.
