Sun Blade ZoneManager is available through the Sun Blade 6000 CMM. This utility enables you to assign storage devices located on Sun Blade storage modules with SAS2-enabled server blades installed in the Sun Blade 6000 chassis.
A SAS2-enabled NEM must be installed in the chassis to enable a server blade to be zoned with storage devices on a storage blade. At this time, zoning of SAS2 external ports on the NEM is not supported. For information on setting up storage zoning, refer to the Oracle ILOM 3.0 documentation.
