oracle home
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE Release 1.2.2 Product Notes
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Sun Blade 6000 Ethernet Switched Network ...
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE ...
Issues Corrected in the Patch Update
Updated: March 2016
Document Information
Using This Documentation
Product Documentation Library
Feedback
NEM Documentation Reading Order
Introducing What's New in Release 1.2
IPv6 Switching and Routing
ONET Protocol
PVRST+ Protocol
Server Load Balancer
Oracle ILOM 3.0 Features
Updates to 1.2 Release From Patch Update
Supported Configurations, Operating Systems, and Required Patches
Required Firmware and Kernel Drivers
Modular System Limitations
Enabling SAS2 Functionality
Important Firmware Upgrade Before Mixing SAS1 and SAS2 Components
Supported Server Modules and REMs
Minimum Required Software
Sun Blade ZoneManager
Upgrading the NEM Firmware
Back Up the Current Configuration Before Upgrading
Download the NEM Firmware Package
Upgrade the NEM Firmware
Enable or Disable SAS2 From Oracle ILOM
Configure 1Gbps Mode on SFP+ Interfaces
Fine Tune the VLAN Setup
Managing SEFOS Configurations
Include the SEFOS Configuration in Backups
Restore the Configuration
Configuring TACACS+
TACACS+ Properties
Configure TACACS+ Settings
Issues Corrected in Prior Updates
Known Issues
SLB-L2 Error is Seen When Reassigning a Port From One LBG Group to Another (7100720)
SLB Must Not Allow Different VLANs in the Same Group (7095155)
SLB L2 Cannot Create More Than Two Groups, SLB L2 Limits to Two LBGs (7092380)
Manually Deleting Static Route Does Not Affect the Corresponding SLB Entry (7064092)
Changing the Default Value for default-vlan-id Could Result in VLAN Misconfiguration (7015004)
Some of the IGMP Conformance Results Don't Match Expectations (7006297 and 6997415)
Ports Lock and Corresponding LEDs Stay Lit or NEM Fails to Power On After Doing Consecutive Hardware Resets (6992127)
QoS - set algo-type tailDrop queue-drop-algo Does Not Work (6991230)
Packets Might Be Dropped When Using Q-in-Q Interop in Certain Configurations (6989048)
The no default-metric [,short(1-16)>] Command Does Not Work as Documented (6987482)
CMM Reports SAS2 on the NEM as Faulty if SAS2 Is Not Enabled (6977266)
Using vlan 1 as Shown in Various Examples in the Documentation Generates Error Codes (6968484)
When Multiple Configuration Scripts Are Run in Parallel, SEFOS Application Can Crash (6936742)
Unlit Link and Activity LEDs for the SFP+ Ports (6873825)
The switch Command Line Option Is Unsupported
SSL V3.0 POODLE DISABLE SSL V3 (19842641)
Language:
English
These issues have been corrected in this update.
Issue Number
Description of Corrected Issue
22543509
Fix for CVE-2015-5600 Bug 22686043. Fix for CVE-2015-3197.
21164486
sefos crashing when an snmpwalk is performed on NEM using OID sefos.
Previous
Next
