By default SAS2 links are disabled on the SAS2 expander firmware for the NEM. To enable SAS2 links and to allow server modules with supported REMs to communicate with the Sun Blade Storage Module M2, you must enable SAS2 from Oracle ILOM.
-> cd /NEM/SAS/ /NEM/SAS /NEM/SAS-> ls Targets: Properties: type = SAS Expander sas_status = disabled Commands: cd show start stop
-> cd /NEM/SAS/
/NEM/SAS
-> start
Are you sure you want to start /NEM/SAS (y/n)? y
Enabling the device will take approximately 2 minutes...
start: SAS Enabled successfully.
-> ls
/NEM/SAS
Targets:
Properties:
type = SAS Expander
sas_status = enabled
Commands:
cd
show
start
stop
-> cd /NEM/SAS/
/NEM/SAS
Are you sure you want to stop /NEM/SAS (y/n)? y
-> stop
Disabling the device will take approximately 2 minutes...
stop: SAS Disabled successfully.
-> ls
/NEM/SAS
Targets:
Properties:
type = SAS Expander
Commands:
cd
show
start
stop
