Download the NEM Firmware Package
After backing up your current configuration, download the NEM firmware upgrade package Sun_Blade_6000_Ethernet_Switched_NEM_24p_10GE_sefos-1_2_2_15.pkg.
- Sign
in to My Oracle Support at: http://support.oracle.com.
- Select the Patches & Updates
tab.
- Under the Patch Search section,
select Product or Family (Advanced Search).
- Type nem in
the Product field and select Sun Blade 6000 10GbE Switch NEM.
- Select the down arrow in the
Release field and select the Sun Blade 6000 10GbE Switch NEM folder.
- Select the 1.2 release.
- Click the Search button.
- Click the number in the Patch
Name column.
- Click Download.
- Click the filename of the .zip
file to begin the download.
- Save the file to an appropriate
location.
- Upgrade the firmware.
See Upgrade the NEM Firmware.
