Skip Navigation Links | |
Exit Print View | |
man pages section 9: DDI and DKI Kernel Functions Oracle Solaris 11 Information Library |
csx_AccessConfigurationRegister(9F)
csx_Parse_CISTPL_BYTEORDER(9F)
csx_Parse_CISTPL_CFTABLE_ENTRY(9F)
csx_Parse_CISTPL_DEVICEGEO(9F)
csx_Parse_CISTPL_DEVICEGEO_A(9F)
csx_Parse_CISTPL_DEVICE_OA(9F)
csx_Parse_CISTPL_DEVICE_OC(9F)
csx_Parse_CISTPL_LINKTARGET(9F)
csx_Parse_CISTPL_LONGLINK_A(9F)
csx_Parse_CISTPL_LONGLINK_C(9F)
csx_Parse_CISTPL_LONGLINK_MFC(9F)
ddi_get_soft_iblock_cookie(9F)
ddi_intr_get_supported_types(9F)
ddi_prop_lookup_byte_array(9F)
ddi_prop_lookup_int64_array(9F)
ddi_prop_lookup_string_array(9F)
ddi_prop_update_byte_array(9F)
ddi_prop_update_int64_array(9F)
ddi_prop_update_string_array(9F)
ldi_prop_lookup_byte_array(9F)
ldi_prop_lookup_int64_array(9F)
ldi_prop_lookup_string_array(9F)
mac_prop_info_set_default_link_flowctrl(9F)
mac_prop_info_set_default_str(9F)
mac_prop_info_set_default_uint8(9F)
mac_prop_info_set_range_uint32(9F)
net_event_notify_unregister(9F)
net_instance_notify_register(9F)
net_instance_notify_unregister(9F)
net_instance_protocol_unregister(9F)
net_protocol_notify_register(9F)
nvlist_lookup_boolean_array(9F)
nvlist_lookup_boolean_value(9F)
nvlist_lookup_nvlist_array(9F)
nvlist_lookup_string_array(9F)
nvlist_lookup_uint16_array(9F)
nvlist_lookup_uint32_array(9F)
nvlist_lookup_uint64_array(9F)
nvpair_value_boolean_array(9F)
pci_plist_lookup_int16_array(9F)
pci_plist_lookup_int32_array(9F)
pci_plist_lookup_int64_array(9F)
pci_plist_lookup_int8_array(9F)
pci_plist_lookup_string_array(9F)
pci_plist_lookup_uint16_array(9F)
pci_plist_lookup_uint32_array(9F)
pci_plist_lookup_uint64_array(9F)
pci_plist_lookup_uint8_array(9F)
scsi_get_device_type_scsi_options(9F)
scsi_get_device_type_string(9F)
scsi_sense_cmdspecific_uint64(9F)
usb_get_current_frame_number(9F)
usb_get_max_pkts_per_isoc_request(9F)
usb_pipe_get_max_bulk_transfer_size(9F)
usb_pipe_stop_intr_polling(9F)
usb_pipe_stop_isoc_polling(9F)
- log a warning message for an audio device
#include <sys/audio/audio_driver.h> void audio_dev_warn(audio_dev_t *adev, const char *fmt, ...);
pointer to an audio device allocated with audio_dev_alloc(9F). This parameter can be NULL if no suitable device pointer is available.
format of message to be displayed
Solaris DDI specific (Solaris DDI)
The audio_dev_warn() function is a convenience wrapper that sends a message to the system console or logs using cmn_err(9F) with a level of CE_WARN. It also prefixes the message with information identifying the device if adev is not NULL.
The format should not contain any trailing newlines, as the newline will be appended by cmn_err() automatically. Unlike cmn_err(), however, no special handling of the first character of the format string is performed.
This function may be called in any context.
