Go to main content
SPARC T5-4 Server Service Manual
Exit Print View
Updated: February 2019
Component Service Categories
Replaceable components fall into these categories:
  • Hot-serviceable by the customer – Hot-serviceable components can be removed while the server is running. Hot-swappable components do not require any preparation prior to servicing. Hot-pluggable components do require preparation prior to servicing.
  • Cold-serviceable by the customer or exclusively by authorized service personnel – Cold-serviceable components require that the server is shut down. In addition, some service procedures require that the power cables be disconnected between the power supplies and the power source.
The following table identifies the server components that are replaceable.
Component
Power Status for Removal
Authorized Service Personnel Only
Remove and Replace Instructions
Processor module
Off
X
DIMM
Off
Hard drive
Off or On
Main module
You must disconnect the ower cords before accessing this component..
Off
Storage backplane*
Off
X
Service processor card*
Off
System configuration PROM*
Off
X
System battery*
Off
Front I/O assembly*
Off
Power supply
Off or On
Fan module
Off or On
PCIe card
Off or On
Rear I/O module*
Off
X
Rear chassis subassembly*
Off
X
Related Information
