/HOST keyswitch_state |
normal |
The server can power on and run POST
(based on the other parameter settings). This parameter overrides
all other commands. |
diag |
The server runs POST based on predetermined settings. |
standby |
The server cannot power on. |
locked |
The server can power on and run POST,
but no flash updates can be made. |
/HOST/diag mode |
off |
POST does not run. |
normal |
POST runs according to diag level value. |
/HOST/diag level |
max |
If diag mode=normal,
runs all the minimum tests plus extensive processor and memory tests. |
min |
runs minimum set of tests. |
/HOST/diag trigger |
hw-change |
(Default) Runs POST following a FRU replacement or
an AC power cycle. |
all-resets |
Runs POST on all resets. |
error-reset |
Runs POST on all error resets. |
power-on-reset |
Runs POST on every power on. |
none |
Does not run POST on reset. |
/HOST/diag hw_change_level |
max |
Runs the maximum set of tests. |
min |
Runs the minimum set of tests. |
/HOST/diag hw_change_verbosity |
min |
(Default) Displays the minimum level
of output. |
max |
Displays information for each step. |
normal |
Displays a moderate amount of information, including
component names and test results. |
debug |
Displays extensive debugging information. |
none |
Disables the output. |
/HOST/diag power_on_level |
max |
(Default) Runs the maximum set of tests. |
min |
/HOST/diag power_on_verbosity |
min |
of output. |
max |
normal |
debug |
none |
/HOST/diag error_reset_level |
max |
min |
Runs a minimum set of tests. |
/HOST/diag error_reset_verbosity |
min |
of output. |
max |
normal |
debug |
none |
/HOST/diag verbosity |
normal |
Displays all test and informational messages
in POST output. |
min |
Displays functional tests with a banner
and pinwheel in POST output. |
max |
Displays all test, informational, and
some debugging messages in POST output. |
debug |
none |
Does not display POST output. |
