Applied power to the server.
See Connect Power Cords.
Powered on the server.
Green System OK LED – lit
Amber System Fault LED – not lit
Amber System Fan Fault LED – not lit
See Front Panel Controls and LEDs and Rear Panel Controls and LEDs.
If these conditions are met, continue to Step 5.
If these conditions are not met, perform the actions described in Diagnostics Process.
-> start SP/faultmgmt/shell Are you sure you want to start the faultmgmt shell (y/n)? y faultmgmtsp>
If faults are reported, see Diagnostics Process.
If no faults are reported, then the fan module has been replaced successfully.
