Remove the Rear I/O Module
The rear I/O module is a cold-service component
that can be replaced by a customer.
- Take
the necessary ESD precautions.
See Prevent ESD Damage.
- Locate the failed rear I/O module.
- Power off the server.
See Removing Power From the Server.
- Disconnect the power cords.
See Disconnect Power Cords.
- Label the cables connected to
the ports on the rear I/O module, and then disconnect the cables
from the ports.
You will reconnect the cables to the same ports on the replacement
rear I/O module.
- Press the green buttons on the
rear I/O module ejection levers, and spread the levers open to eject
the rear I/O module.
- Pull the module away from the
server to remove it.
