Go to main content
SPARC T5-4 Server Service Manual
Exit Print View
Updated: February 2019
Install a PCIe Card
Caution
Caution  - This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause failure of server components.
  1. Determine your first step:
    1. If you are installing a new PCIe card and need an empty PCIe card carrier, see Remove a PCIe Card Carrier.
    2. If you are replacing a faulty PCIe card and have already removed its carrier from the server, go to Step 2.
    3. If you are installing a PCIe card that requires a PCIe carrier extension, see Install a PCIe Carrier Extension.
  2. Remove the PCIe card from its packaging.
  3. Insert the PCIe card into the PCIe card carrier until the bottom connector is firmly seated in the PCIe card carrier's connector.
    image:Figure showing how to install a PCIe card into its carrier.
    Caution
    Caution  -  Do not twist or turn the PCIe card as you insert it into the PCIe card carrier. Ensure that the PCIe card's connector is fully seated in the PCIe card carrier's slot, and that the notch in the PCIe card's rear bulkhead is seated around the PCIe carrier's alignment tab.
  4. Close and latch the PCIe card carrier's top cover.
    image:Figure showing how to close and latch a card carrier's top cover.
Related Information
