Exit Print View
You can install a mix of hard disk drives and solid state drives. The server requires at least one hard drive to be installed and operational.
Supported Storage and Backup Devices
Component Service Task Reference
Hard Drive Hot-Service Capabilities
Hard Drive LEDs
Determine Which Hard Drive Is Faulty
Remove a Hard Drive
Install a Hard Drive
Verify the Hard Drive
