Refer to the ILOM documentation for network configuration instructions.
This will keep the levers from being damaged when the main module is outside the server.
![]() | Caution - Due to the weight of the main module, the following step requires two people to perform. Do not attempt to lift the main module alone. |
Press the green button near the front edge of the cover and slide the cover back and up off the main module.
