Hard drives are hot-service components that can be replaced by customers. For the location of the hard drives, see Hard Drive Locations.
![]() | Caution - This procedure requires that you handle components that are sensitive to electrostatic discharge. This discharge can cause failure of server components. |
Drives are physically addressed according to the slot in which they are installed. If you are replacing a drive, install the replacement drive in the same slot as the drive that was removed. See Hard Drive Locations for drive slot information.
