Applied power to the server.
See Connect Power Cords.
Started the system.
See Rear I/O Module LEDs.
-> start SP/faultmgmt/shell Are you sure you want to start the faultmgmt shell (y/n)? y faultmgmtsp>
If a fault was detected, see Diagnostics Process.
If no faults were detected, then the rear I/O module has been replaced successfully. No further action is required.
