If you require technical support for your server, you will be asked to provide the server's serial number.
-> show /System /SYS Targets: MB MB_ENV RIO PM0 PM1 FM0 ... Properties: type = Host System ipmi_name = /System keyswitch_state = Normal product_name = T5-4 product_part_number = 602-1234-01 product_serial_number = 0723BBC006 fault_state = OK clear_fault_action = (none) power_state = On Commands: cd reset set show start stop
