Determine
Which Fan Module Is Faulty
The following LEDs are illuminated when a fan
module fault is detected:
System Service Required LEDs on the
front panel and rear I/O module
Server Fan Fail LED on the front panel
Service Required LED on the faulty fan module
- Determine
if the System Service Required LEDs are illuminated on the front panel
or the rear I/O module.
See Interpreting LEDs.
- Determine if the Server Fan Fail
LED on the front panel is illuminated.
See Front Panel Controls and LEDs.
- From the rear of the server,
check the fan module LEDs to identify which fan module needs to
be replaced.
The fan module Service Required LED is illuminated on the
fan module that needs to be replaced.
- Remove the faulty fan module.
See Remove a Fan Module.
